GetObjects has an optional ‘objects’ argument that allows selection only within a predetermined set of objects. Is there a reason that GetObject() does not have the same option?
Hi Mitch,
not sure if this is helpful to you but if you could set maximum_count of GetObjects() to 1, you have the same functionality as GetObject() with the abillity to define objects and limit to grouped objects. But you would set group=False and have this grp_filter:
def grp_filter(rhino_object, geometry, component_index):
# only allow objects in groups
return rhino_object.Attributes.GroupCount > 0
The result is then the first (single) object in the returned list:
obj_ids = rs.GetObjects("Select", 0, False, False, False, None, 1, 1, grp_filter)
Instead of None you would pass your obj ids to limit selection to. Is this what you’re trying to do ?
_
c.
Hi Clement,
Thanks, this was more of a request to add that optional argument to GetObject(). I think the word ‘group’ in my title was confusing, I’ll change that…
Yes, the workaround is using GetObjects(), it’s actually a bit simpler than your example, basically just limit the selection count to minimum/maximum 1 object, plus passing the list of objects to select from in the ‘objects’ argument.
obj_ids = rs.GetObjects("Select", 0, False, True, False, [obj_coll], 1, 1)
