I am writing a python script that makes use of the ExplodeCurves command in rhinoscriptsyntax. However I noticed that the command does not give the same result as when I go through the process manually.
If you use the attached file and dummy script, you will see that calling the Explode command in Rhino will return 6 curves. While using the python script only returns 2 curves.
Is this intentional? If so what am I missing?
ExplodeCurve.3dm (22.8 KB)
ExplodeCurve.py (119 Bytes)
Hi @Hunter2,
The difference is that the underlying function behind rs.ExplodeCurves is Curve.DuplicateSegments, and the Explode command uses RhinoObject.GetSubObjects.
Here is a more equivalent script:
import Rhino
import scriptcontext as sc
def test_explode_curve():
# Pick a single curve object
filter = Rhino.DocObjects.ObjectType.Curve
rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select curve to explode", False, filter)
if not objref or rc != Rhino.Commands.Result.Success:
return
# Get the selected Rhino object
rh_obj = objref.Object()
if not rh_obj:
return
# Get the sub0objects
sub_objs = rh_obj.GetSubObjects()
if not sub_objs:
return
# Add the sub-object geometry
for sub_obj in sub_objs:
sc.doc.Objects.Add(sub_obj.Geometry)
sc.doc.Objects.Delete(rh_obj)
sc.doc.Views.Redraw();
if __name__ == "__main__":
– Dale
This is perfect! Thanks so much!
