Hi I’m using rhino 7 on my home desktop computer, using two monitors (described below) and when I use the “right-click” to select objects by layer, for example, the popup menu does not appear, or appears far from the chosen layer, when I have the monitor scaled to a different size other than what is “recommended”.
Main monitor: 3840 x 2160
Second monitor: 1920 x 1080
In the image below, the menu is on my main monitor, and it appears in in the middle of the window.
For my smaller monitor, if I scale to 100% the menu does not even appear.
Is this a bug? Or is there a way to make the selection menu always appear next to the layer that I’m clicking on?
Thanks!
