Hy all,
yesterday while trying to load rhinoscriptsyntax inside a python3 component in gh i got the silliest error. i Cant figure put ho to solve it, i have tried uninstalling rhino 8 and installing it back up, looked also at the search paths inside the scripting component and they all look like the should do. Also if y run a python2 component i dont get the same silly error.
Does any one have an idea on how to solve this?
Thanks in advance.
Rhino 8 SR18 2025-4-10
Have you made another module called string.py, that’s being imported preferentially over the actual core library’s string.py (or otherwise messed around with that)?
Hi James, thanks for the reply. No i havent made any new modules. And in the search paths i havent put any more modules to import.
@arquiaz Try deleting the .rhinocode\py39-rh8\site-rhinopython folder and lunch Rhino. When opening script editor this folder should be deployed again. See if that fixes the problem.
Thanks Ehsan, just before reading your solution it occurred to me while reading this two posts ( Rhino - Script Editor Options ) & ( Rhino - Python Path Files ) That i needed to dive deep into the folders generated by rhino at some point. So i deleted the folder you suggest after removing rhino and installing it back again. And that did the trick!
Thanks for the help !
Anytime
