Rhinoscriptsyntax Command Bugging GH canvas?
I have this pretty simple script that prompts the user to draw a line via RhinoScriptSyntax (rs.GetLine) in Rhino and then uses that to Scale a Grasshopper object but when I complete the rhino input portion it sometimes locks the gh interface in a weird way where I can’t click on my canvas components.
I figure this is probably an issue with script context switching, component expiration, or some kind of “rhino command is complete” value being returned but I’m stuck and cannot figure out how to get it to prevent the canvas clicking from bugging out.
Graph Space:
Python Code:
#! python 3
__author__ = "Michael Vollrath"
__version__ = "2024.07.14"
# Made With ♥ In Dallas, TX
ghenv.Component.Description = "Given a user-drawn line, scales an object to the user-specified dimension."
ghenv.Component.Name = "Scale Line"
ghenv.Component.NickName = "SL"
ghenv.Component.Params.Input[0].Name = "Object"
ghenv.Component.Params.Input[0].NickName = "O"
ghenv.Component.Params.Input[0].Description = "Object To Scale"
ghenv.Component.Params.Output[0].Name = "Object Scaled"
ghenv.Component.Params.Output[0].NickName = "OS"
ghenv.Component.Params.Output[0].Description = "Object Scale Result"
import Rhino
import scriptcontext as sc
def scale_object():
    # Prompt the user to select the object to scale
    obj = O
    if not obj:
        return
    # Prompt the user to draw a line
    line = rs.GetLine()
    if not line:
        return
    pt1, pt2 = line[0], line[1]
    if not pt1 or not pt2:
        print("Invalid line drawn. Please draw a valid line.")
        return
    # Calculate the current distance between the two points
    current_distance = rs.Distance(pt1, pt2)
    if current_distance == 0:
        print("The distance between the points is zero. Please draw a valid line.")
        return
    # Prompt the user for the desired dimension
    desired_dimension_str = rs.GetString("Enter the desired dimension between the two points")
    try:
        desired_dimension = float(desired_dimension_str)
    except ValueError:
        print("Invalid input for the desired dimension. Please enter a valid number.")
        return
    # Calculate the scale factor
    scale_factor = desired_dimension / current_distance
    # Perform the scaling operation
    scaled_obj = rs.ScaleObject(obj, pt1, (scale_factor, scale_factor, scale_factor))
    if not scaled_obj:
        print("Scale Failed.")
        return
    if "scaled_obj" not in sc.sticky:
        sc.sticky["scaled_obj"] = scaled_obj
    res = sc.sticky["scaled_obj"]
    print("Object scaled successfully.")
    return res
# Execute the function
if __name__ == "__main__":
    if E:
        OS = scale_object()
    elif "scaled_obj" in sc.sticky:
        OS = sc.sticky["scaled_obj"]
    else:
        OS = None
    # OS = scale_object()
    sc.doc = ghdoc
System Info
Rhino 8 SR9 2024-7-8 (Rhino 8, 8.9.24190.17001, Git hash:master @ c9e437cfdf6e9fc57bba3cd084318a04f8b7e355)
License type: Commercial, build 2024-07-08
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.17
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 2-9-2024 (M-D-Y).
> External USB display device with 4 adapter port(s)
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
Primary OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 1-15-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.24
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-26-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
> External USB display device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-15-2023
Driver Version: 31.0.15.2824
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24138.1238
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp “Crash” 1.4.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.1.0.0
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24190.17001
Thank you all for your help!
Please see attached .gh:
20240714_RS_Command_Preventing_GH_Mouse_Interaction_01a.gh (658.9 KB)
sc.doc is never set to Rhino.RhinoDoc.ActiveDoc but I’m not sure when it should be switched back to make changes to the GH canvas.
Thanks @James_Parrott ,
I did have it set initially before the rs.get command but that did not seem to make a difference nor did even having it set back to ghdoc at the end as you show in the snip.
Perhaps it is just a matter of “where” the context switching occurs but I use rhinoscriptsyntax and Rhinocommon methods quite often and it has never messed up my mouse interactions in the GH canvas before so I’m quite confused.
I’ll try setting context to the doc immediately before rs.getline and ghdoc immediately after and see if that helps
Thanks for your help and insights!
Try using “toggle” instead of “button”
Maybe this post would help.
https://discourse.mcneel.com/t/toggle-button-single-click/68635
Thanks @Alex43, I’ll give it a go and report back
