Hello, everyone
I’m trying to develop a script to offset a closed curve certain distance, I’m using this code but it does not work. It may be possible to get some help with it?
Option Explicit
Function RhinoOffsetClosedPlanarCurve(ByVal strCurve, ByVal dblDistance, ByVal blnOutside)
' Local variables
Dim arrPlane, arrOldPlane, strView, arrBox, arrPoint
' Default return value
RhinoOffsetClosedPlanarCurve = Null
' Quick parameter validation
If (VarType(strCurve) <> vbString) Then Exit Function
If Not IsNumeric(dblDistance) Then Exit Function
If (VarType(blnOutside) <> vbBoolean) Then Exit Function
' Curve validation
If (Rhino.IsCurve(strCurve) = False) Then Exit Function
If (Rhino.IsCurveClosed(strCurve) = False) Then Exit Function
arrPlane = Rhino.CurvePlane(strCurve)
If Not IsArray(arrPlane) Then Exit Function
' Calculate plane-based bounding box
strView = Rhino.CurrentView()
arrOldPlane = Rhino.ViewCPlane(strView, arrPlane)
arrBox = Rhino.BoundingBox(strCurve, strView)
Call Rhino.ViewCPlane(strView, arrOldPlane)
' Offset point so its outside of bounding box
arrPoint = Rhino.PointAdd(arrBox(0), Rhino.VectorCreate(arrBox(0), arrBox(2)))
' Offset the curve
If (blnOutside = False) Then dblDistance = -dblDistance
RhinoOffsetClosedPlanarCurve = Rhino.OffsetCurve(strCurve, arrPoint, dblDistance, arrPlane(3))
End Function
