Rhinoscript "Command" function - Automatically pass input without user intervention
I want to use certain Rhino commands, which are not available in Rhinoscriptsyntax in my script.
For example, I have downloaded a plugin which allows user to set notes to objects using a command “SetObjectNotes”. After running this command in Rhino, it asks the user to select object and then a box pops up where the user can type in the note.
I want to automate this process in a script, where I can run Rhino.Command("_SetObjectNotes" … after which i want to pass in the object ID and then the text to be added.
Similar to this I want to try other commands too where I can pass in ObjectID or some other parameter when User input is prompted.
Thanks in advance
Hi
FWIW: many if not most Rhino native command have a hyphened version
this allows for user input at the commandline through a macro and as such can be scripted
( try Command: -SaveAs vs Command: SaveAs)
However I think for plugins you rely on the plugin make to provide Commandline input, you could ask the plugin maker if these options exist
-Willem
Hello - Willem is correct - setObjectNotes is a script compiled into a plug-in, and not a Rhino command - you can reuse the code in your script, if that helps:
SetObjectNotes.py (738 Bytes)
Thank you! Solved the problem.
Thank you! Solved the problem. The script was helpful.
