Hello ,
From the plugin rhino , we can use the function , RhinoRepairBrep to make a valid brep , is it possible to have the same function for opennurbs library without any rhino function ?
thanks
Laurent
Hello ,
thanks
Laurent
Probably not. Opennurbs is the library with which you can read and write 3dm files. As such it provides a rich data structure, but no advanced modeling functions, like repairing BReps.
Hello ,
as we can create a brep with c++ sources so I suppose every body don’t have always a perfect brep (with tolerance vertex/edge, seam , north/west …) errors , so is it possible to have the way that uses the RhinoRepairBrep function , I will implement it or I need to get from the IsValid method and repair when we get an error .
thanks
Laurent
Hi @eraud,
I’ve logged your openNURBS request.
https://mcneel.myjetbrains.com/youtrack/issue/RH-57681
Thanks,
– Dale
Hello Dale ,
thanks for your help to add this method , I don’t know if is possible to have it into opennurbs framework .
is it possible to have the function that you have into rhino , the source code or the algorithm, I will modify it with opennurbs classes , I suppose it is not possible !!! it is a dream …
have a good day .
thanks
Laurent
Hi @eraud,
The issue I created targets 7.x, which means it won’t be available when Rhino 7 ships. But it should be available sometime during the Rhion 7 lifecycle.
– Dale
Hello Dale ,
ok
thanks
Laurent
