Hello guys,
unfortunately, I have to raise few question regarding the RhinoInside. My goal is to create a Excel add-in which update opened Rhino/GH file and recompute few components or open Rhino/GH and visibly manipulate it.
After few days of tries and errors I discovered two possible ways.
RhinoInterface, leading to com object.
RhinoInside, which should be new tool to implement Rhino and GH to third party softwares. Without RhinoInside implementation into code, I cannot use all parts of RhinoCommon as some parts of rhinocommon_c library cannot be loaded.
Probably leading to similar class which should be able to manipulate Rhino and GH files.
Unfotunately, I am not able to put my code into operation. I cope with following problems.
I am not able to connect to open document. I can open opened document with C# but any changes (disabling solver) are not shown in my opened document. I think my code open document for second type.
With RhinoInterface (Com object) I am not able to cast Com object to GH_RhinoScriptInterface class.
So my questions are:
- Are my suggestions correct?
- Is my goal possible?
- If so, what is best way to achieve my goal? RhinoInside? And how?
- How opened/running rhino files can be connected and manipulated? (I tried many samples from Git but without success).
- How to use RhinoInsideExcel?
Thank you for your replies and time.
Ondřej
