That is the complete code. Line 3 above is where it stops waiting for point input. No clicking or typing satisfy the input request. I’ll try rolling back to a previous build.
@dale Do you know if anything changed recently with maybe how your application handles MouseCapture? The reason I ask, is that if you execute our code in a command, where your Rhino Process has focus it works fine.
However with our hybrid application, we also execute code in Rhino via our ServerPlugin when does all our work in Rhino. So our UI has focus, then initiate the above code, and now Rhino is no longer aware that we are clicking in the viewport.
Our Rhino MouseCallback however is receiving all of the events. And much of the Rhino UI still responds to the mouse, but the RhinoGet does not see any clicks…
Unfortunately it would be difficult to reproduce the exact scenario because we have our own application process which talks to a Rhino Plugin via WCF. The plugin is telling Rhino what to do, in this case the above 3 lines.
I am trying to test our plugin using old WIP builds, but I cannot get our plugin to load any longer in older WIPs. Is Plugin Loading disabled in Expired WIP builds?
I am also having an issue where after hiding and then showing the Rhino Window using ShowWindow() api call causes viewports to stop painting.
We have to hide the Rhino Window whenever we have UI that needs to show on top of it, to avoid airspace issues between WPF and MFC/WinForms.
If you have an idea when things fell apart, it would be very helpful.
Rhino WIPs expire after 45 days. I can get you any WIP you need up to 45 days ago. Beyond that, you’d have to fiddle with your system clock. But to answer your question, expired WIPs won’t run at all.
Is the “Rhino Window” the main Rhino window? Is ShowWindow a p/invoke call into Win32?
I’m creating a Chromium Browser (using CefSharp) that sits in a System.Windows.Forms.Panel in a UserControl in a DockBar. I’ve overridden the OnBeforeBrowse method of the CefSharp.Handler.RequestHandler so that it intercepts a request of a particular schema and triggers a RhinoGet.GetPoint call.
The command shows up in the Rhino command window, but refuses to respond to any input or return from the call. (The same thing happens with GetNumber, etc.)
Other commands seem to work find (e.g. doc.Objects.AddLine).
These GetPoint command also works find outside of the browser request handler (e.g. in a simple Button attached to the UserControl).
