RhinoDoc.ReadFile interrupted with 'import scaling - DimensionNumbers'
I am using ReadFile and also defining FileReadOptions:
However, the import is still interrupted saying “import scaling - DimensionNumbers”
I am using the ReadFile command to import a .3dm rhino file.
Related post:
Hi @atharvaranade4,
Can you provide me simple code sample, that I can run here, that repeats this?
Thanks,
– Dale
using Rhino;
using Rhino.Commands;
using System;
namespace ImportCodeSnippet
    public class ImportCodeSnippetCommand : Command
        public ImportCodeSnippetCommand()
            Instance = this;
        public static ImportCodeSnippetCommand Instance { get; private set; }
        public override string EnglishName => "ImportCodeSnippetCommand";
            RhinoApp.WriteLine("The {0} command is under construction.", EnglishName);
            Rhino.FileIO.FileReadOptions options = new Rhino.FileIO.FileReadOptions
                BatchMode = true,
                ImportMode = true,
                ScaleGeometry = true,
                UseScaleGeometry = true,
            string filepath = Environment.ExpandEnvironmentVariables(@"%AppData%\SnippetSamplePlugin\1_Production.3dm");
            var result = Rhino.RhinoDoc.ReadFile(filepath, options);
            return result ? Result.Success : Result.Failure;
Note: We are using ‘%AppData%’ for the sake of this demo code snippet.
Please find attached rhino file:
1_Production.3dm (168.9 KB)
Hi @atharvaranade4,
Thanks, I’ve logged the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-67948
– Dale
