this is my first time posting here a question in the forum=) I recently started working on RhinoCommon and RhinoCompute. I have been facing issues when converting our RhinoCommon PlugIn.
I hope this is the right place to discuss the problem I ran into:
Till now we are using Open() and we don’t have any issue opening and generating reports from it.
Apparently, I am running into an issue when using the RhinoDoc Methods:
When I open .3dm file using OpenHeadless() method, it’s unable to load layout properties properly. I can view all the layouts in doc.Views but the layouts are not loaded properly. Views like Top, Bottom, Right, Left… are loading fine.
doc = RhinoDoc.OpenHeadless(@“C:\Sample.3dm”);
Works fine when i use doc = RhinoDoc.Open(@“C:\Sample.3dm”);
I tested this by creating a file with a layout and one detail. I use RhinoDoc.OpenHeadless() and in doc.Views I see 4 RhinoView and 1 RhinoPageView.
What I do see is that the loaded RhinoPageView has bounds of {X=0,Y=0,Width=0,Height=0} where as if I open the file directly, the bounds are {X=0,Y=0,Width=283,Height=200}
Yes, that’s the issue.
I can’t read RhinoPageView which stores layout details. All the properties are set to default.
But when I open Rhino I can see all the details.
Till i get the proper fix, I will try to use File3dm.Read() method to read the file.
