RhinoCommon: unable to get RenderMaterial of object
Hi all,
In a python script I’m trying to retrieve the renderMaterial of an object, but it seems I’m not doing it right. This returns an error:
import Rhino
objTypesFilter = Rhino.DocObjects.ObjectType.Brep & Rhino.DocObjects.ObjectType.Mesh
rc, objRef = Rhino.Input.RhinoGet.GetOneObject( "Select object", False, objTypesFilter )
obj = objRef.Object()
renderMaterial = obj.Attributes.RenderMaterial
In my defense the error is not super helpful:
I’m testing this script on the most simple object possible:
sample.3dm (65.6 KB)
My Rhino version:
Rhino 8 SR8 2024-6-11 (Rhino 8, 8.8.24163.12481, Git hash:master @ ded4d86ca901dbeaf13ee84f79b3e91b22da4880)
What is the right way to get the renderMaterial of a RhinoObject in RhinoCommon ?
Hello- something like this perhaps
import Rhino
import scriptcontext as sc
mats = sc.doc.Materials
attrs = obj.Attributes
idx = attrs.MaterialIndex
if idx != -1:
    renderMaterial = mats[idx]
    print renderMaterial.Name
Thank you @pascal
Your script above works nicely to get the material from the object in the 3dm file I sent in my first message.
If I try again on the same object in a scene where there are other objects, I get a new error:
Here is the scene: bla.3dm (415.7 KB)
The object that worked-but-now-doesn’t is this one in red:
doesn’t RhinoObject.Attributes.MaterialIndex return the index of the Material in sc.doc.Materials rather than the RenderMaterial in sc.doc.RenderMaterials ?
Hi Felix - sorry - use
sc.doc.Materials
@felix.mariotto RenderMaterial is directly on the RhinoObject ( https://developer.rhino3d.com/api/rhinocommon/rhino.docobjects.rhinoobject/rendermaterial?version=8.x# )
import Rhino
renderMaterial = obj.RenderMaterial
print(renderMaterial)
thanks
Ah great, thank you both a lot !
By the way, when obj.RenderMaterial gives you None then no material has been assigned, and you should use the default material. This is just an instance of the default plaster material. Here a small update with default material usage:
#! python3
import Rhino
import Rhino.Render
defaultRenderMaterial = Rhino.Render.RenderContentType.NewContentFromTypeId(Rhino.Render.ContentUuids.PlasterMaterialType)
if not renderMaterial:
    renderMaterial = defaultRenderMaterial
@nathanletwory thank you for the precision !
