RhinoCommon Transformation matrix
Is it possible to use RhinoCommon transformation matrix in such a way, that I could define transformation axis?
The code below is something I am trying to translate, and wondering if there is alterative in for defining transformation matrices
// construct a transform matrix from our axes
glm::mat3x3 object_transform;
object_transform[0] = vector0; //Vector
object_transform[1] = vector1; //Vector
object_transform[2] = vector2; //Vector
// invert the matrix
glm::mat3x3 object_to_world_transform = glm::inverse(object_transform);
// transform the outward normal (vector) using the matrix
glm::vec3 normal = object_to_world_transform * axis_z;
Should work - i just did something similar: I recreated a cameraprojection matrix with values i took from a blender camera matrix. It worked as expected, but you have to be careful with the coordinate systems: left/right handed, y-up and z-up… also the matrices can be column or row major it seems… Took me a few tries to get the right sequence.
Rhinocommon Transform should already have all the methods you need.
I have never worked with matrices.
Is it possible to get an example how to:
  1. Create Matrix of 3x4 I assume in C# it is lilke this:
Rhino.Geometry.Matrix m = new Rhino.Geometry.Matrix(3, 4);
  1. How to assign values to rhino matrix?
    Basically I have 4 points and want to create matrix like this:
    | x0.x x0.y x0.z 1 |
    | x1.x x1.y x1.z 1 |
    | x2.x x2.y x2.z 1 |
    | x3.x x3.y x3.z 1 |
  2. And calculate determinant of it?
My knowledge of matrices is also not the best, but you should use the rhino.transform class, as it has way more functions implemented and is basically a 4x4 matrix…
Transform t = new Transform(0);
t.M00 = x0.x;
t.M01 = x0.y;
etc..
double determinant = t.Determinant;
If the result looks wrong, swap rows and columns.
The transformation matrix is indeed a 4x4 matrix. The 3x3 sub-matrix defines the scaling and rotation matrix, and the 4th column’s first 3 entries the translation. The fourth row’s elements are all zero except the last one that is 1:
| r00 r01 r02 | t0 |
| r10 r11 r12 | t1 |
| r20 r21 r22 | t2 |
|   0   0   0 |  1 |
Such a 4x4 matrix can encode all affine transformations (i.e. rotation, translation, scaling, shearing, etc.)
For more information, google it or start reading here https://math.stackexchange.com/questions/336/why-are-3d-transformation-matrices-4-times-4-instead-of-3-times-3
Thanks for the reply,
I trying to solve unify mesh windings problem by reading this stackoverflow post:
However It seems that it does not work for me or I simply do not know enough about matrices.
Could you please take a look at my code. The function below check if the winding is clockwise or not, but far from working outputting correct true and false statements:
private void RunScript(Mesh x, Point3d y, ref object A)
unify.gh (22.5 KB)
    bool[] f = new bool[x.Faces.Count];
    for(int i = 0; i < x.Faces.Count; i++){
      x.Faces[i] = x.Faces[i].Flip();
      Vector3f vecA = new Vector3f (x.Vertices[x.Faces[i].A].X, x.Vertices[x.Faces[i].A].Y, x.Vertices[x.Faces[i].A].Z);
      Vector3f vecB = new Vector3f (x.Vertices[x.Faces[i].B].X, x.Vertices[x.Faces[i].B].Y, x.Vertices[x.Faces[i].B].Z);
      Vector3f vecC = new Vector3f (x.Vertices[x.Faces[i].C].X, x.Vertices[x.Faces[i].C].Y, x.Vertices[x.Faces[i].C].Z);
      //Vector3f v0 = Vector3f.Subtract(vecA, vecB);
      //Vector3f v1 = Vector3f.Subtract(vecB, vecC);
      //Vector3f v2 = Vector3f.Subtract(vecC, vecA);
      //f[i] = CheckWinding(vecA, vecB, vecC, y);
      f[i] = CheckWinding(v0, v1, v2);
    A = f;
  // <Custom additional code>
  public bool CheckWinding(Vector3f v0, Vector3f v1, Vector3f v2)
    //Calculate three axis
    Vector3f axis_x = v1 - v0;    // edge v0 -> v1
    Vector3f axis_y = v2 - v0;    // edge v0 -> v2
    Vector3f axis_z = Vector3f.CrossProduct(axis_x, axis_y);
    axis_z.Unitize();
    //Construct a transform matrix from our axes
    t.M00 = axis_x.X;
    t.M01 = axis_x.Y;
    t.M02 = axis_x.Z;
    t.M03 = 1;
    t.M10 = axis_y.X;
    t.M11 = axis_y.Y;
    t.M12 = axis_y.Z;
    t.M13 = 1;
    t.M20 = axis_z.X;
    t.M21 = axis_z.Y;
    t.M22 = axis_z.Z;
    t.M23 = 1;
    t.M30 = 0;
    t.M31 = 0;
    t.M32 = 0;
    t.M33 = 1;
    //Invert the matrix
    t.TryGetInverse(out t);
    //Transform the outward normal using matrix
    axis_z.Transform(t);
    return (axis_z.Z > 0);
Looks to me like the check posted on Stack Exchange is flawed. The matrix represents a transformation to the local space of the basis defined by axes x, y, and z. Applying this transformation to the z axis will always result in (0,0,1), so, unless I’m missing something, this just seems like a very expensive way of checking if the z axis is pointing in the same direction as itself.
Yeah, this does not work. For me it looked super complex way for checking windings.
But after playing with matrices several times and seeing random results, I gave up.
