RhinoCommon Transform.ChangeBasis VS Transform.PlaneToPlane
Hello all,
I am just confused about the difference between the Transform.ChangePlane vs the Transform.PlaneToPlane.
Under the hood, this is what we have:
        // Summary:
        //     Computes a change of basis transformation. A basis change is essentially a remapping
        //     of geometry from one coordinate system to another.
        // Parameters:
        //   plane0:
        //     Coordinate system in which the geometry is currently described.
        //   plane1:
        //     Target coordinate system in which we want the geometry to be described.
        // Returns:
        //     A transformation matrix which orients geometry from one coordinate system to
        //     another on success. Transform.Unset on failure.
        public static Transform ChangeBasis(Plane plane0, Plane plane1)
            Transform xf = Identity;
            if (!UnsafeNativeMethods.ON_Xform_PlaneToPlane(ref xf, ref plane0, ref plane1, rotation: false))
                return Unset;
            return xf;
        // Summary:
        //     Create a rotation transformation that orients plane0 to plane1. If you want to
        //     orient objects from one plane to another, use this form of transformation.
        // Parameters:
        //   plane0:
        //     The plane to orient from.
        //   plane1:
        //     the plane to orient to.
        // Returns:
        //     The translation transformation if successful, Transform.Unset on failure.
        public static Transform PlaneToPlane(Plane plane0, Plane plane1)
            UnsafeNativeMethods.ON_Xform_PlaneToPlane(ref xf, ref plane0, ref plane1, rotation: true);
            return xf;
Both are calling the same native method, with the difference of the rotation being true or false. So I did the following simple code:
                    // Test:
                    Plane ptest = new Plane(
                        new Point3d(50, 50, 50),
                        //Point3d.Origin,
                        new Vector3d(StaticExtension.random.NextDouble(), StaticExtension.random.NextDouble(), StaticExtension.random.NextDouble()));
                    Transform planetoplane = Transform.PlaneToPlane(Plane.WorldXY, ptest);
                    Transform changebasis = Transform.ChangeBasis(ptest, Plane.WorldXY);
                    Point3d p_planetoplane = new Point3d(StaticExtension.random.NextDouble(), StaticExtension.random.NextDouble(), StaticExtension.random.NextDouble());
                    Point3d p_changebasis = p_planetoplane;
                    p_planetoplane.Transform(planetoplane);
                    p_changebasis.Transform(changebasis);
This is what I see in the debug window:
If you can’t see, note:
1- The Transform objects returned have the same values in the matrix. THE SAME. Even planetoplane == changebasis.
2- Well, then obviously the point transformed results are the same…
Is this really the expected behaviour? Is this a special case of some sort?
The description of the methods is ultra confusing, specially because BOTH versions have from/to, and they return the same matrix but in one case my ptest is the from and in the other it is the to.
From my tests, say you have something like a planar curve that you draw programatically on the WorldXY so that it is easier, then you want to orient it to at a given plane targetplane.
In this case, you may either - they are the same transformation
Transform.PlaneToPlane(Plane.WorldXY, targetPlane) - This one makes sense because the curve is on the WorldXY and you want it to be in the targetPlane. From/To are ok.
Transform.ChangeBasis(targetPlane, Plane.WorldXY) - Could you please help me understand what is going from the targetPlane to the WorldXY in this case?
Thanks!
Ha ! In encountered the ‘reversed’ behaviour of ChangeBasis a few days ago and was also confused to the point i thought this may be a bug… but I missed PlaneToPlane and this enlightens the difference.
If you have an object in p0 “coordinate system” and want to view it in p1 “coordinate system”, you are actually doing a PlaneToPlane of this object from p1 to p0, which explains why those transforms are inverse of each other.
Hi @magicteddy ,
Thanks for the help. Perhaps my mind is simply stupid, but I still don’t get it - specialyl what is the use of 2 functions that have the same name of their parameters and that return the same value - only the order of the parameters is the same.
That is why I asked if I am not looking at the full picture (special case).
Even if this is not a bug in the code, I truly believe that the documentation is deficient. As you said, you were also confused and I think I even saw a post from the creator of Grasshopper where he also says he is confused.
There has to be a way to make this less confusing, specially as this is such a basic transformation that we use all the time.
Have a good sunday!
Hi @dale,
Thank you so much. I feel very stupid, to be honest. I have already had this issue in the past, and I had seen this very same answer of yours. But, I’m sure this already happened to you: I just forgot about it.
I feel that regardless of all this, the description of the documentation could be improved - both for the OpenNurbs and the RhinoCommon.
Thanks a lot.
