RhinoCommon selected subobjects to remain selected when script ends?
Is it possible to have script-selected subobjects remain selected after the script finishes?
I am using the following to select certain edges from a brep. (just draw a box that sits on the world XY plane, it should select all the edges but the bottom ones, one at a time)
import scriptcontext as sc
import Rhino
def EdgeFilter(edges,plane,joined,tol):
    #returns only those brep edges that correspond to filter criteria
    #modify filter function as needed
    filtered_edges=[]
    for edge in edges:
        crv=edge.ToNurbsCurve()
        if not crv.IsInPlane(plane,tol):
            if joined:
                if not edge.TrimCount>1: continue
            filtered_edges.append(edge)
    return filtered_edges
def TestFunction():
    objID=rs.GetObject("Select polysurface",16)
    if not objID: return
    plane=Rhino.Geometry.Plane.WorldXY
    tol=sc.doc.ModelAbsoluteTolerance
    rhobj=rs.coercerhinoobject(objID)
    brep=rs.coercebrep(objID)
    #apply the edge filter to get only the edges you want.
    filtered_edges=EdgeFilter(brep.Edges,plane,True,tol)
    #select the desired edges
    for edge in filtered_edges:
        rhobj.SelectSubObject(edge.ComponentIndex(),True,True)
        #for visualizing purposes only
        sc.doc.Views.Redraw()
        rs.Sleep(500)
TestFunction()
However the selected edges are unselected when the script ends. I see there is another post with a similar question, but the answer was
…but the selection does only remain while the script is running and does not stay, so it cannot be used to make eg. a transformation with a pre-selected subobject after the script finished.
Hi Mitch,
since Rhino 6 there is a third overload persistentSelect which seems to do it:
rhobj.SelectSubObject(edge.ComponentIndex(),True,True,True)
merry christmas,
c.
Ah, cool, I looked right at that one and I still missed it… :dizzy_face:
