Continuing the discussion from How can I use Plane.FitPlaneToPoints from Python correctly?:
I was also confused when I initially tried to use a function that modified an input variable in-place, using rhinocommon and Python. I got this error when I tried passing in a python boolean to Mesh.TopologyEdges.GetEdgesForFace(Int32,Boolean[]):
TypeError: expected StrongBox[Array[bool]], got bool
So, to avoid similar confusion, here is an example using the Mesh.TopologyEdges.GetEdgesForFace(Int32,Boolean[])
method. The method “gets the indices of the edges that surround the given face.”
import clr
import System
import Rhino.Geometry as geom
import scriptcontext
def get_edges_orientations_for_face(mesh,face):
returns a list of tuples: [(edgeIndex,alignedWithFace),...]
where edgeIndex is the index of the TopologyEdge in the mesh
and alignedWithFace is a boolean which is True if the edge direction is consistent with the face
orientations = clr.StrongBox[System.Array[bool]]()
edges = mesh.TopologyEdges.GetEdgesForFace(face,orientations)
edges = list(edges)
orientations = list(orientations.Value)
edges_with_orientations = zip(edges,orientations)
return edges_with_orientations
def make_mesh():
creates an upright square mesh with two triangular faces
vertices = []
vertices.append((0.0,0.0,0.0))
vertices.append((5.0,0.0,0.0))
vertices.append((5.0,0.0,5.0))
vertices.append((0.0,0.0,5.0))
face_vertices = []
face_vertices.append((0,1,3,3))
face_vertices.append((1,2,3,3))
rhino_mesh = create_mesh(vertices,face_vertices)
return rhino_mesh
def create_mesh(vertices,face_vertices):
'''add a mesh to doc and get the Rhino.Geometry.Mesh object'''
mesh_GUID = rs.AddMesh( vertices, face_vertices )
obj = scriptcontext.doc.Objects.Find(mesh_GUID)
return obj.Geometry
if __name__ == "__main__":
mesh = make_mesh()
face = 0
edges_with_orientations = get_edges_orientations_for_face(mesh,face)
print "for face {}, got oriented edge tuples: {}".format(face,edges_with_orientations)
I found it very helpful to look at IronPython documentation. The section on Typed Arrays helped significantly.
