In RhinoCommon, how to I set up a prompt for object selection that’s restricted to a certain list of objects?
Thanks,
James
Thanks,
James
i am asuming you´re still working with RhinoCommon from within Python. If this is the case check out the GetObjects()
rhinoscript syntax from here, it allows to pass a custom object list in the object
argument.
Alternatively, if you want to have less code, why not use rhinoscriptsyntax >>> rs.GetObjects()
c.
