Two questions:
- Is it possible to register Event Watcher for specific GUID?
- Is it possible to recognize movement of the control point (for curve, surface or mesh) and not general modification (translation, rotation and etc)
Thanks,
Dmitriy
Two questions:
Thanks,
Dmitriy
Hi @Dmitriy,
How about this:
public static void OnReplaceRhinoObject(object sender, RhinoReplaceObjectEventArgs e)
if (m_my_object_id == e.ObjectId)
// TODO...
This is possible in C++ using a CRhinoOnTransformObject
watcher. I don’t believe this is available in RhinoCommon. Why is this important? Is a RhinoDoc.ReplaceRhinoObject
event sufficient?
– Dale
Thanks @dale,
For the first one I end up with the same approach.
For second one - I am performing some actions after control points have been modified. So the solution I currently found is to check selected objects in Rhino and verify if selected object type is ObjectType.Grip
inside ReplaceRhinoObject
watcher.
Another small question - is it allowed to have only one and only instance of EventWatcher?
Thanks,
Dmitriy
Yep. But I’d keep the number to something reasonable…
– Dale
