i have a Brep / Cylinder / Surface of Revolution - (internalized in attached gh file).
TryGetCylinder()
will find the radius and the plane, but the height is 0;
setting some default heights (0..10) the cylinder is showing.
what is wrong - do I expect to much from TryGetCylinder ?
I would claim it s a bug ?
thanks for having a look.
kind regards.
Tom
public class Script_Instance : GH_ScriptInstance
private void RunScript(Brep brep, bool setDefaultH, ref object a, ref object h)
a = null;
Cylinder cyl;
if (!brep.Faces[0].TryGetCylinder(out cyl)) return;
if (setDefaultH)
cyl.Height1 = 0;
cyl.Height2 = 10;
// Write your logic here
a = cyl.ToRevSurface();
h = cyl.TotalHeight;
tryGetCylinderBug_00.gh (7.1 KB)
EDIT:
workaround
use this function as workaround.
if you don’t like multiple returns / early returns you will not like the code.
if you have any other improvements - happy to read your comments.
private bool TryGetCylinderWithHeight(Surface srf, out Cylinder cylinder, double tolerance = 0.001)
cylinder = Cylinder.Unset;
Cylinder cylinderBack;
if (!srf.TryGetCylinder(out cylinderBack,tolerance)) return false;
if (cylinderBack.TotalHeight < tolerance * 10)
Plane plane = cylinderBack.BasePlane;
if (!plane.IsValid) return false;
BoundingBox bbox = srf.GetBoundingBox(plane);
if (!bbox.IsValid) return false;
double h1 = bbox.Min.Z;
double h2 = bbox.Max.Z;
if (Math.Abs(h2-h1) < tolerance * 10) return false;
cylinderBack.Height1 = h1;
cylinderBack.Height2 = h2;
cylinder = cylinderBack;
return true;
