Hi There,
In rhino7 I was used to running a piece of code that runs an external instance of python3.11, to perform functionality that wasn’t available in Ironpython2.7.
If I run the same piece of code in Rhino8 I get an error, likely related to the PYTHONHOME variable judging by this post.
To me it seems that Rhino8 has set the PYTHONHOME variable and I need to make sure that the check_output() call does not use this variable
Does anyone know how to solve this issue?
Thanks,
Tim
Status : CalledProcessError 1
Python path configuration:
PYTHONHOME = '\\?\C:\Users\info\.rhinocode\py39-rh8'
PYTHONPATH = (not set)
program name = 'python'
isolated = 0
environment = 1
user site = 1
safe_path = 0
import site = 1
is in build tree = 0
stdlib dir = 'C:\Users\info\.rhinocode\py39-rh8\Lib'
sys._base_executable = 'C:\\Program Files\\Python311\\python.exe'
sys.base_prefix = '\\\\?\\C:\\Users\\info\\.rhinocode\\py39-rh8'
sys.base_exec_prefix = '\\\\?\\C:\\Users\\info\\.rhinocode\\py39-rh8'
sys.platlibdir = 'DLLs'
sys.executable = 'C:\\Program Files\\Python311\\python.exe'
sys.prefix = '\\\\?\\C:\\Users\\info\\.rhinocode\\py39-rh8'
sys.exec_prefix = '\\\\?\\C:\\Users\\info\\.rhinocode\\py39-rh8'
sys.path = [
'C:\\Program Files\\Python311\\python311.zip',
'C:\\Users\\info\\.rhinocode\\py39-rh8\\Lib',
'C:\\Users\\info\\.rhinocode\\py39-rh8\\DLLs',
Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
Python runtime state: core initialized
ImportError: bad magic number in 'encodings': b'a\r\r\n'
Current thread 0x0000435c (most recent call first):
<no Python frame>
#! python 2
# example_test_file.py
import json
import sys
from subprocess import check_output, STDOUT, CalledProcessError
def main():
try:
# example payload
input = { 'a':'my_value' }
json_data = json.dumps(input, ensure_ascii=False).encode('utf-8')
# Call external process in python3, send payload as json string
filename = 'RunTestFile.py'
output = check_output(['python', filename, '-i', json_data], stderr=STDOUT, shell=False, universal_newlines=True, creationflags = 0x08000000)
# Temp disabled, try with exact executable path
# path = r'C:\Program Files\Python311\python.exe'
# output = check_output([path, filename, '-i', json_data], stderr=STDOUT, shell=False, universal_newlines=True, creationflags = 0x08000000)
# process the output
lines = output.split('\n')
for line in lines:
try:
# try to capture any line that looks like a response in json
response = json.loads(line)
if response['status'] != None:
return response
except Exception as exc:
# print any other output
print('py3 output : %s' % (line))
except CalledProcessError as exc:
# capture timeouts
if exc.returncode == -1073741510:
return {'status':False, 'msg':'API call timeout'}
# print the external process error
print("Status : CalledProcessError", exc.returncode)
lines = exc.output.split('\n')
for line in lines:
print(line)
print(exc)
if __name__ == '__main__':
main()
#! python3
# example_file_to_execute.py
import sys
print('version from instance:', sys.version)
