[Rhino8] Purge() Object Freezes Rhino if a single object is selected
Strange one for you - Purging Objects - can Freeze Rhino - but only if you have an object selected.
I can replicate this on two differently specified windows 11 PC’s but not on a 3rd.
Notice the 5 second lag the second time the script is run below!
PurgeBug
This is a toy example but the real issue is causing up to 10minute freezes on our CNC machines & preventing our recommending an upgrade to Rhino 8 to customers.
To reproduce
  1. Open new Document
  2. Run Script
  3. Notice times are very close together
  4. Draw a rectangle
  5. Select Rectangle
  6. Run Script
  7. Notice Significant Freeze and gap between times
using System;
using Rhino;
using System.Linq;
using Rhino.Geometry;
using Rhino.DocObjects;
var doc = RhinoDoc.ActiveDoc;
// create / find reference layer
int layerId = doc.Layers.FindName("Ref")?.Index ??  doc.Layers.AddReferenceLayer(new Layer {	Name = "Ref"});
var layer = doc.Layers.FindIndex(layerId);
// add reference objects
for (int i = 0; i < 1000; i++)
        var circle = new Circle(50).ToNurbsCurve();
        doc.Objects.Add(circle,new ObjectAttributes {LayerIndex = layerId});
Console.WriteLine("Created "+ DateTime.Now.ToString("hh.mm.ss.ffffff"));
// delete them
doc.Objects.FindByLayer(layer)?.All(doc.Objects.Purge);
Console.WriteLine("Deleted " +DateTime.Now.ToString("hh.mm.ss.ffffff"));
SysInfo_Occurs.txt (2.3 KB)
SysInfo_DoesNotOccur.txt (2.4 KB)
We updated the Nvidia driver on one affected machine and the slowdown running the above script with a rectangle selected went from a 5 second to 40 seconds (!)
SysInfo_Occurs_Driver_Update.txt (2.3 KB)
Hi @david.birch.uk,
I will try to look at this later this week.
Thanks,
– Dale
Hi @david.birch.uk,
Your script seems fast here on my 3 year old Dell laptop - between 13 and 16 milliseconds. No freeze ups or lags.
– Dale
Thanks @dale
Same on my Dev PC, but this is occuring on several customer PC’s
Lag only occurs if objects are selected.
Anyone else able to replicate? Just open a new document & c# script editor, paste above and record times.
David
Hi @david.birch.uk ,
I have tried it and I can’t reproduce it either.
Could you please send us information about the computers on which it is not working properly? Please check that they have the latest service version of Rhino 8 installed and that Windows has all updates installed.
Thank you @Guillermo_Varela & @dale
I can confirm this problem was resolved in Rhion 8.6 - I am no longer able to replicate it on the problematic machines. :slight_smile:
Good afternoon,
I am able to recreate the same issue using the same steps
This is my current system info:
SystemInfo.txt (2.3 KB)
This issue is occurring in 8.7 for us unfortunately.
I suspect it specific to the GPU in question a Geforce GTX 1650
Hello David
Can you try to disable all Plug-ins that do not ship with Rhino , using the plug-in manager, and re-test?
The system’s video card is not the issue as the script never redraws the screen.
Thanks
Hi @cecile unfortunately we are still seeing the same slowdown with no plugins loaded.
sysinfo (2).txt (2.2 KB)
DavidBirch2.cs (1.5 KB)
Hi @david.birch.uk , please download and test this slightly modified version.
Let us know if that works.
Thank you @Guillermo_Varela i have tested this today on 8SR8 & SR9 with both your script and mine. I am unable to replicate the issue. Your script reliably runs in 3-4ms regardless of whether anything is selected.
I note with interest that there was a NVidia driver update installed on the machine on June 12th so i suspect this resolved this issue.
Will report if this crops up again.
