Hi all,
I just discovered the rhino3dm package and I have issues to add objects in a File3dmObjectTable:
I want to read all the objects in my .3dm model and select the ones that are part of the layers given by the user. And then I want to get the bounding box of the objects.
For that, I decided to create a new File3dmObjectTable, to fill it with the desired objects and then apply the GetBoundingBox() method the get what I want. But when I try to use the several Add() methods to the new File3dmObjectTable I always get a TypeError on the arguments.
Does anyone know if I’m not using the methods in the right way, or is it a bug and there is a better way to have the bounding box ?
Thanks for your help!
Here is my code with the Add() method. I tryied also with the AddBrep() one.
def getObjects(model, layers):
objects = File3dmObjectTable
for object in model.Objects:
if object.Attributes.LayerIndex in layers and object.Attributes.Mode == ObjectMode.Normal:
objects.Add(object.Geometry, object.Attributes)
return objects
it returns :
objects.Add(object.Geometry, object.Attributes) TypeError: Add(): incompatible function arguments. The following argument types are supported: 1. (self: rhino3dm._rhino3dm.File3dmObjectTable, geometry: rhino3dm._rhino3dm.GeometryBase, attributes: rhino3dm._rhino3dm.ObjectAttributes = None) -> object Invoked with: <rhino3dm._rhino3dm.Brep object at 0x072C6640>, <rhino3dm._rhino3dm.ObjectAttributes object at 0x072C6620>
with the AddBrep() method:
if object.Geometry.HasBrepForm:
objects.AddBrep(object.Geometry, object.Attributes)
return objects
it returns :
objects.AddBrep(object.Geometry, object.Attributes) TypeError: AddBrep(): incompatible function arguments. The following argument types are supported: 1. (self: rhino3dm._rhino3dm.File3dmObjectTable, brep: rhino3dm._rhino3dm.Brep, attributes: rhino3dm._rhino3dm.ObjectAttributes = None) -> object Invoked with: <rhino3dm._rhino3dm.Brep object at 0x07A69620>, <rhino3dm._rhino3dm.ObjectAttributes object at 0x07A69600>
