Rhino3dm: face get mesh always None!
Hello , what is the error in this code? always GetMesh(rh.MeshType.Any) is None.
The file is a simple cube
import rhino3dm as rh
file = "..../cube.3dm"
rf = rh.File3dm.Read(file)
for obj in rf.Objects:
        geo = obj.Geometry
        if geo.ObjectType == rh.ObjectType.Brep:
            faces = geo.Faces
            for i in range(len(faces)):
                print i, faces[i]
                mesh = faces[i].GetMesh(rh.MeshType.Any)
                print mesh
0 <rhino3dm._rhino3dm.BrepFace object at 0x00000000037E4650>
None
1 <rhino3dm._rhino3dm.BrepFace object at 0x00000000037E4650>
None
2 <rhino3dm._rhino3dm.BrepFace object at 0x00000000037E4650>
None
3 <rhino3dm._rhino3dm.BrepFace object at 0x00000000037E4650>
None
4 <rhino3dm._rhino3dm.BrepFace object at 0x00000000037E4650>
None
5 <rhino3dm._rhino3dm.BrepFace object at 0x00000000037E4650>
None
If the .3dm file was not saved with render meshes, then there won’t be any meshes to get.
Feel free to post your .3dm file.
– Dale
Thanks , in the simple box file i hit render button than save and the script work fine but with another model and the same method don’t work.
And this wok fine with extrusion unlike faces
if geo.ObjectType == rh.ObjectType.Extrusion: geo.GetMesh(rh.MeshType.Any)
file = "....../test.3dm"
    geo = obj.Geometry
    print geo
        #geo.GetMesh(rh.MeshType.Any)
        faces = geo.ToBrep(True).Faces
            print i, faces[i]
            print mesh
This is the 3d file:
test.3dm (77.5 KB)
You need to save your file with one viewport in Shaded or Rendered mode.
Thanks, dont’t wok the same message None
For an extrusion it is better to directly GetMesh. This is what we do in import_3dm blender add-on as well. I guess creatiing a Brep from the extrusion still doesn’t give you the render meshes, as the brep hasn’t been meshed yet.
Thank you , so import in Blender also need this ?
Yes.
