Rhino testing github action stopped working
hi @fraguada ,
We’ve had an action on our github for almost two years now that has worked well with no changes.
Recently it started failing and I don’t see anything changed, not in our action, and not in the action on the mcneel side. But perhaps you have an idea of what is going on.
From our logs on github
 with:
    email-address: ***
  env:
    RHINO_TOKEN: ***
    DOTNET_ROOT: C:\Program Files\dotnet
Downloading and installing the latest Rhino 3d...
Error: Error: Command failed: Start-Process -FilePath c:\temp\rhino_setup.exe -ArgumentList '-passive', '-norestart' -Wait
Start-Process : This command cannot be run due to the error: The file or directory is corrupted and unreadable.
At line:1 char:1
+ Start-Process -FilePath c:\temp\rhino_setup.exe -ArgumentList '-passi ...
    + CategoryInfo          : InvalidOperation: (:) [Start-Process], InvalidOperationException
    + FullyQualifiedErrorId : InvalidOperationException,Microsoft.PowerShell.Commands.StartProcessCommand
Error: get-itemproperty : Cannot find path 'HKLM:\SOFTWARE\McNeel\Rhinoceros\8.0\Install' because it does not exist.
At line:1 char:32
+ ...  [Version] (get-itemproperty -Path HKLM:\SOFTWARE\McNeel\Rhinoceros\8 ...
    + CategoryInfo          : ObjectNotFound: (HKLM:\SOFTWARE\...ros\8.0\Install:String) [Get-ItemProperty], ItemNotFo
   undException
    + FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.GetItemPropertyCommand
and the action we’re using ourselves is:
on:
  push:
    branches: [ "Release" ]
env:
  RHINO_TOKEN: ${{ secrets.RHINO_TOKEN }}
jobs:
  build-and-release:
    runs-on: windows-latest
    steps:
    - uses: actions/checkout@v3
    - name: Setup .NET
      uses: actions/setup-dotnet@v3
      with:
         dotnet-version: 7.0.x
    - name: Install Rhino
      uses: mcneel/setup-rhino3d@v2
      with:
        email-address: ${{ secrets.RHINO_EMAIL }}
    - name: Restore dependencies
      run: dotnet restore
    - name: Build (Yak Build Configuration)
      run: dotnet msbuild LINK_EP.sln /t:Rebuild /p:Configuration="Yak Build" /v:minimal
    - name: Test
      run: dotnet test -c "Yak Build" --no-build --verbosity normal --framework "net7.0-windows"
Edit: It seems to be working when i reran it. must be temporary downtime on the mcneel installer host or connectivity between that and github.
