Hey guys,
How can I color specific chosen edges in Rhino? I´ve been trying to solve it with the CRhinoConduit Class, but it never actually worked.
This is the current Code I am working with:
class CSampleHighlightCurveConduit : public CRhinoDisplayConduit
public:
CSampleHighlightCurveConduit();
bool ExecConduit(CRhinoDisplayPipeline& dp, UINT nChannel,bool& bTerminate);
public:
unsigned int m_runtime_object_serial_number;
CSampleHighlightCurveConduit::CSampleHighlightCurveConduit()
: CRhinoDisplayConduit( CSupportChannels::SC_OBJECTDISPLAYATTRS )
// TODO: initialize members here
bool CSampleHighlightCurveConduit::ExecConduit( CRhinoDisplayPipeline& dp,UINT nChannel,bool& bTerminate)
switch( nChannel )
case CSupportChannels::SC_OBJECTDISPLAYATTRS:
if( m_pChannelAttrs->m_pObject->m_runtime_object_serial_number == m_runtime_object_serial_number ){
m_pDisplayAttrs->m_ObjectColor = RGB(255,0,0);
m_pDisplayAttrs->m_EdgeColor = RGB(255,0,0);
break;
return true;
And this is Main Method:
CRhinoCommand::result CCommandEdgePicker::RunCommand( const CRhinoCommandContext& context )
CRhinoGetObject gv;
gv.SetCommandPrompt(L"Select Edge");
gv.SetGeometryFilter(CRhinoGetObject::meshedge_object);
gv.GetObjects(1,1);
if(gv.CommandResult() != CRhinoCommand::success){
return gv.CommandResult();
const CRhinoObject* obj = gv.Object(0).Object();
const ON_MeshEdgeRef* ref = gv.Object(0).MeshEdge();
conduit->m_runtime_object_serial_number = obj->m_runtime_object_serial_number;
conduit->SetGeometryFilter(CRhinoGetObject::meshedge_object);
conduit->Enable();
context.m_doc.Redraw();
return CRhinoCommand::success;
This code does nothing. What do I do wrong?
Thanks in Advance.
