I have a little mystery here… The above code is my way to check that when I use Rhino.ReadTextFile I do get an array of text lines (arrText)… and usually it is the case.
But sometimes, the very same command used with the very same txtFile does not behave the same : the condition “isArray(arrText) becomes False” and of course my program stops here.
Do you have any clue why this happens ? The txt file and my code are both on my C:/
Do you have a way of repeating this? Do you have the same issue if you read the file using a FileSystemObject?
Sub ReadTextFile()
Dim objFSO, objFile, strFileName, strLine
Const ForReading = 1
strFileName = Rhino.OpenFileName("Open", "Text Files (*.txt)|*.txt||")
If IsNull(strFileName) Then Exit Sub
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.OpenTextFile(strFileName, ForReading)
While Not objFile.AtEndOfStream
strLine = objFile.ReadLine
Rhino.Print strLine
Wend
objFile.Close
Set objFSO = Nothing
End Sub
