Rhino Lower case to upper case
Hello All,
Is there a way to switch lower case texts to upper cases in Rhino? I am trying to change all the room labels for the project I am working on to upper case.
Highly appreciate any tips.
thanks,
Mahsa
Something like this smalll scriptlet should work:
def to_filt(rhino_object, geometry, component_index):
    return rs.IsText(geometry)
def ConvertTextToUppercase():
    msg="Select text blocks to convert to uppercase"
    text_objs=rs.GetObjects(msg,512,preselect=True,custom_filter=to_filt)
    if not text_objs: return
    for text_obj in text_objs:
        text=rs.TextObjectText(text_obj,rs.TextObjectText(text_obj).upper())
Thank you very much, Helvetosaur!
