Rhino keeps crashing when using Maxwell 5 plugin on MAC
My Rhino keeps crashing when i try to turn the fire on in the maxwell plugin for Rhino and i cant render with maxwell plugin for Rhino. I get the following error -
Process: Rhinoceros [2799]
Path: /Applications/Rhinoceros 2.app/Contents/MacOS/Rhinoceros
Identifier: com.mcneel.rhinoceros
Version: 6.20 (6.20.19323.01022)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Rhinoceros [2799]
User ID: 501
Date/Time: 2019-11-25 12:20:44.466 +0000
OS Version: Mac OS X 10.14.6 (18G103)
Report Version: 12
Anonymous UUID: 0560223D-CC70-2BF3-EDAD-56115EA61316
Sleep/Wake UUID: 8E44584F-F16A-40B3-A3EE-04B7EEB2CA87
Time Awake Since Boot: 7600 seconds
Time Since Wake: 2300 seconds
System Integrity Protection: enabled
Crashed Thread: 0 tid_307 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Rhinoceros [2799]
Application Specific Information:
[ERROR] FATAL UNHANDLED EXCEPTION: System.ArgumentOutOfRangeException: StartIndex cannot be less than zero.
Parameter name: startIndex
at System.String.Substring (System.Int32 startIndex, System.Int32 length) [0x00004] in <58fec105cf57445bb2c0c7448bbc82b3>:0
at maxwell_rhino.Exporter.getExportNameWithoutExtension () [0x00043] in <567a192543874311803fa72c07cb1131>:0
at maxwell_rhino.FireEntities.FireDisplayMode.StartRenderer (System.Int32 w, System.Int32 h, Rhino.RhinoDoc doc, Rhino.DocObjects.ViewInfo view, Rhino.DocObjects.ViewportInfo viewportInfo, System.Boolean forCapture, Rhino.Render.RenderWindow renderWindow) [0x0006d] in <567a192543874311803fa72c07cb1131>:0
at Rhino.Render.RealtimeDisplayMode.OnStartRenderer (System.IntPtr realtimeViewport, System.UInt32 w, System.UInt32 h, System.UInt32 docSerialNumber, System.IntPtr view, System.IntPtr viewPort, System.Boolean forCapture, System.IntPtr rw) [0x00030] in <0496ef763bbe4c7fb6c0f2e449a0d889>:0
at (wrapper native-to-managed) Rhino.Render.RealtimeDisplayMode.OnStartRenderer(intptr,uint,uint,uint,intptr,intptr,byte,intptr)
[END ERROR]
!ë˝ëˇˇ
Can anyone please help with this?
Thanks
Hi Rebecca - please contact Technical Support at Next Limit for help with this.
Thanks,
Hi Rebecca,
Having the same issue from the 1st day using Maxwell 5. Did you find the solution?
Best,
ZC
