Hi @d.c.segraves,
Wee need to update that section, EnqueueAction
is no more available.
Here an updated sample
using System;
using System.Collections;
using System.Collections.Generic;
using Rhino;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
using RhinoInside.Revit;
using RhinoInside.Revit.Convert.Geometry;
using DB = Autodesk.Revit.DB;
/// <summary>
/// This class will be instantiated on demand by the Script component.
/// </summary>
public class Script_Instance : GH_ScriptInstance
/// <summary>
/// This procedure contains the user code. Input parameters are provided as regular arguments,
/// Output parameters as ref arguments. You don't have to assign output parameters,
/// they will have a default value.
/// </summary>
private void RunScript(bool Trigger, double Radius, ref object Sphere)
if(Trigger == false) return;
if(Radius < Revit.VertexTolerance * 10.0) return;
var doc = Revit.ActiveDBDocument;
using(var tx = new DB.Transaction(doc, Component.NickName))
tx.Start();
Sphere = CreateSphere(doc, Radius);
tx.Commit();
// <Custom additional code>
private DB.DirectShape CreateSphere(DB.Document doc, double radius)
var sphere = new Rhino.Geometry.Sphere(Rhino.Geometry.Point3d.Origin, radius);
var brep = sphere.ToBrep();
var revitCategory = new DB.ElementId((int) DB.BuiltInCategory.OST_GenericModel);
var ds = DB.DirectShape.CreateElement(doc, revitCategory);
var shapeList = new List<DB.GeometryObject>() { brep.ToSolid() };
ds.AppendShape(shapeList);
return ds;
// </Custom additional code>
