How to use Rhino.Inside.Revit with Rhino Compute? What will it take to run in a VM like AWS EC2?
Perhaps, Rhino.Inside.Revit itself needs an active Revit instance (running on AWS?). You could hook up hops to ‘do something’ or send out something to be computed. If you can provide more details of the environment/workflow as a whole I can see what’s available. Thanks
