Hi Rhinocommunity, I would like to share a plugin I developed…made out of neccessity:
Rhino Explode v1.0.0
Manually creating exploded views in Rhino3D is tedious and time-consuming. Rhino Explode automates the entire process, allowing you to showcase the internal mechanics, assembly logic, and relationship between multi-part objects in just a few clicks. Whether you are designing complex machinery, consumer products, or architecture, Rhino Explode turns dense CAD models into clear, professional visual narratives.
What RhinoExplode does
Automatic explode‑lines
Drag‑preview while adjusting distances
Smart tag rendering (camera‑facing, anti‑overlap, offset)
Multi‑object explode
Bolt / nut / washer / standoff detection
Snapshot‑ and Named Positions-proof transforms
Works with meshes, solid, polysurfaces, SubD, blocks (as single objects)
Fully undo‑safe
Zero setup — install and go
Downloads
Food4Rhino: 15 days trial
Gumroad: full version license
Why?
This Plugin is a result of the work and experience from the Open Lab Starter Kit project at InMachines
It started with the idea that anyone should be able to assemble complex machines without technical knowledge. The simplest way was to create very clear assembly instructions, inspired by Ikea but improved where needed. Our first project was a manual for the Fabulaser Mini. The whole process is described here.
That manual was static and limited: just two states, parts in and parts out, frozen in a PDF. We realized the next version had to be interactive and 3D.
Then we had to create manuals for six machines, which meant manually moving around 20,000 fasteners in Rhino and drawing all translation curves. After finishing, it was obvious I needed a Rhino plugin to automate this work for future projects. Because it didn’t excist, I decided to make it myself.
you can have a look at the online manual for a small CNC here
This is the first public release — feedback, bug reports, and feature requests are very welcome. I’m actively improving the plugin and will update it frequently.
Thanks to everyone who tested early builds and helped refine the workflow.
