Rhino Common and Python "Box.Z"
I’m trying to access the Rhino.Geometry.Box.Z method to give the Z height of a bounding box, but can’t get a handle on the syntax for using Rhino Common functions with Python. Can anyone explain? preferably with an example.
Hi Adam,
Not a true answer but to get the max Z of a Boundingbox as returned by rhinoscriptsyntax try this:
def Main():
    obj_id = rs.GetObject('getobject for boundingbox')
    if not obj_id: return
    bbox = rs.BoundingBox(obj_id)
    #get Z value of the bbox first upper corner
    print bbox[4].Z
Main()
Does that help?
-WIllem
Yes, perfect, I’m still curious about how I can use rhinocommon methods with python, but this does what i’m after.
In Grasshopper this works:
- I have a box connected to a Python component
- The input is called 'Box'
- Type hint is 'Box'
print(Box.BoundingBox.Max.Z)
Here is another mix of rhinoscriptsyntax (just to select the object) and RhinoCommon…
import scriptcontext as sc
import Rhino
def TestGetBB():
    objID=rs.GetObject("Select object for bounding box",preselect=True)
    if not objID: return
    obj=sc.doc.Objects.Find(objID).Geometry
    bb=obj.GetBoundingBox(False)
    if bb: print "Bounding box max Z is {}".format(bb.Max.Z)
TestGetBB()
interesting. Can you point me to any good resources for understanding the rhino common syntax in rhino.python? the googles is kind of failing me on this one.
You can start here:
The API reference with all the classes is here:
Windows
Mac
You will need to understand at least a little how Python’s object oriented programming syntax works.
HTH, --Mitch
