Rhino BETA Feature: In-Viewport Visibility
In the Rhino BETA, we’ve added commands to manage in-viewport display of objects.
What is this Feature?
This feature makes it possible to have selected objects only appear in specific viewports, while they are hidden in others.
Why this Feature?
In previous versions of Rhino, you could hide objects in all viewports or none.
Having per-viewport visibility, however, gives you more control over your scene management:
  • For sketching: showing a Picture in one viewport, while visualizing the geometry in another. This avoids images cluttering the view as you trace your curves.
  • For design iterations: having design variations per viewport for comparison and decision-making.
  • For scene management: visualizing different components of a project - each in a different viewport - can bring clarity to the different parts.
  • Something else? Let us know!
How It Works
The commands we’ve included are:
  1. HideInViewports
  2. ShowInViewports
  3. IsolateInViewports
  4. UnisolateInViewports
  5. ShowSelectedInViewport
  6. SelIsolated
Try it:
  1. Download and open sketch.3dm (3.9 MB) in the Rhino BETA.
  2. Select the images in the Top and Front viewports.
  3. Run the HideInViewports command.
    → Ensure that HideIn is set to SelectedViewports
  4. Click in the Perspective viewport and press Enter.
  5. Run the Curve command.
  6. Start tracing away!
Notes
These commands only work on model space geometry. When an object in layout space is preselected while running these commands, it will be deselected, and the user is asked to select an eligible object. Objects in model space that are visible in details are eligible objects.
When an object is hidden in all but a specific viewport or viewports, creating new details will not show the object. Creating new floating viewports will also not show the object.
When details are deleted or floating viewports are closed, and an object becomes invisible in all remaining viewports, the ShowSelectedInViewport command makes it possible to show that object in an existing viewport.
Download the Rhino BETA and Try It Out!
This is for me the greatest new thing along with the Concept DisplayMode.
Hi @wim. Will there be icons in toolbars for theese fantastic new possibilities? Maybe a connection to Show/Hide ABC in the IsolateSelected
Hey Tim -
Please make sure to use the Reset command to ensure that your toolbars are on the latest version.
