Rhino AI feedback workflow and needed features
I’ve been using McNeel’s Rhino MCP server and Grasshopper 2 (Rhino 9 beta) with Claude, and it’s been going surprisingly well.
My work is mostly product design (extruded or 3-axis machined parts) plus product rendering. I know an experienced user can model this faster by hand. This post is about what the AI workflow is like and what makes it work better.
Task 1: Rendering, building and tuning PBR materials and lighting
I gave it a photo of a finished product and had it match the camera and lens to the shot. Then it iterated on lighting and materials until the render was close to the photo.
  • Ask for a spread of options (A/B/C/D) and choose yourself. It isn’t good at judging what looks “real” in fine detail.
  • Give it reference photos of the real material if you have them.
Task 2: Rebuilding a STEP part as a parametric GH2 definition
I set this up as building a reusable skill that:
  1. Asks how the part will be manufactured (in this case an extruded profile, machined on four sides). That decides how it gets sketched.
  2. Rebuilds the part in GH2 with named sliders. A GH2 graph is much easier for an AI to work with than raw geometry, because it can change one value and re-solve.
That worked well. The pain point was making changes. To adjust a single fillet on a baked part, I had to trace it back through the GH definition myself and then tell the AI where to look.
So, I (As in asked Claude to) build a small tool called FeatureContext:
  • Bake with provenance: Parts are baked with GH2’s own bake, which tags each object with the component it came from, plus some extra metadata.
  • Pick and comment: You pick a face or edge in the viewport and type a note, e.g. “make this a hard edge”. The script walks back through the GH2 graph to the component that created that face and lists the sliders that drive it. It copies a summary to paste into the AI chat and saves a screenshot with the face highlighted.
With that, the AI knows exactly which component and slider to change, rather than making a long chain of tool calls to find it.
Questions
  • Does something like this already exist? As far as I can tell, the context you can currently give the AI is the viewport, layers, or whole objects.
  • McNeel folks: is feature-level context like this on the roadmap for Rhino MCP / the AI tools?
Generally the RhinoAI panel is still very early days. So generally we do intend to be able to give more context and skills to focus and refine the outcomes from RhinoAI.
You can give AI more prompts and the information you describe above the RhinoAI. But, right now it is all temporarily in the chat window itself.
We know this is a request. I am not sure what is possible, but we are working to expand the harness and we will see what is possible.
Thanks Scott,
The AI window is a pretty good starting point and however you have done the MCP documentation is good as opus 5.5 is not having any issues tool calling with it. I did do a bit via terminal with the MCP as well for the photo comparison.
For grasshopper apart from the metadata we embed does it have any traceability on a baked part? Not an expert on how Rhino bodies are defined.I’m more from an Onshape background where you click on a chamfer and it highlights the feature used for that part.
I’ll get it to replicate an open source machining test step and post that with the GH code and the skill/ feature select as an example of the workflow.
Edit:
So I got it to rebuild a test model Download Free CAD Models, STEP Files, and Test Results | NIST
NIST PMI Test Model - FTC 8
Canvas on GH2, this has metadata in it so you can use the FeatureContext function click on part of the baked model and ask it to change that part.
Full folder with the example file and Skill, machining check scripts and readme for the FeatureContext.
This requires Rhino9 WIP and GH2
STEP to GH2 example - NIST FTC-08.zip (2.6 MB)
