I am re visiting some old scripts and as you can see below I used to add a point in World co ordinates in the following fashion pulling Dim 1 from an ini file
Back in the days of Rhino 3 I wrote some scripts and they had to use world co ordinates, the problem I found was that depending which viewport was active at the time the script was run then the local co ordinate system was being used unless I prefixed the array with “W”. i have tried the line of code as you suggest but I get an error. Nearly all the data I work with is in ini style files so need to be able to call up specific Dims when needed. As we now have V6 to play with I thought it about time I revisited and improved them.
Yeah, that’s wrong actually, I misread your line of code. But in any case Rhino.AddPoint(Array(x,y,z)) will always use world coordinates, it doesn’t care about which viewport is active.
I would still try to convert those strings first to real number point coordinates and then feed that to Rhino.AddPoint().
