Rhino 8 missing block instance count confirmation
In Rhino 7, when selecting blocks in the block manager, you get a nice confirmation telling you how many instances could be selected in the model’s current state.
It’s sadly entirely missing in Version 8 SR3 (8.3.24009.15001, 2024-01-09).
Rhino_4hYjAtgSjQ
Was this removal intentional? It’s extremely useful to my workflow, as I usually know the counts I have, and this helps a lot to notice when something is wrong or missing.
If not a prompt like Rh7 had, could Rh8 at least report the instances it was able to select in the command line at the top?
Hi Duncan - I see this, thanks - I’d say the selection report should be on the command line like any other selection.
RH-80103 BlockManager: report selection at the command line
Excellent Pascal, thank you. I would agree with the command line being the ideal spot.
Hi Duncan -
As I mentioned in a different thread where you participated, the 8.5 version has changes to the block manager:
The number of instances in the scene is always visible; you don’t have to click an extra button just to see this number.
Hi Wim, that’s good, but not the concern of this topic: to see how many blocks were selectable when the select command from the BM was used.
These counts won’t regard hidden or locked state. Essentially the same as ‘SelBlockInstanceNamed’.
Hi Duncan - True, sorry. Reading too fast, I only got “count”.
For now, when you use the Select Instances menu option in the BM, you will see how many were selected in the Properties panel.
RH-80103 is fixed in Rhino 8 Service Release 13
Wow, excellent.
Thanks Brian. Keen to try this out.
