Rhino 8 - I can't import pandas in rhino's ScriptEditor
I have successfully installed numpy and pandas in the Rhino Python path using pip install (CMD). I am able to import and use numpy in the Rhino script editor without any issues. However, when I attempt to import pandas, it seems to be causing some problems.
The code error is as follows:
[0 1 2 3 4 5 6 7 8 9]
Traceback (most recent call last):
File “file:///G:/%E5%90%8C%E6%AD%A5%E8%B5%84%E6%96%99/OneDrive%20-%20lyrics5816/%E8%AE%BE%E8%AE%A1%E7%B4%A0%E6%9D%90/GH/%E4%B8%AA%E4%BA%BA%E7%A0%94%E7%A9%B6/python/pandas%20test.py”, line 5, in
File “C:\Users\97471.rhinocode\py39-rh8\lib\site-packages\pandas_init_.py”, line 73, in
from pandas.core.api import (
File “C:\Users\97471.rhinocode\py39-rh8\lib\site-packages\pandas\core\api.py”, line 1, in
from pandas.libs import (
File "C:\Users\97471.rhinocode\py39-rh8\lib\site-packages\pandas_libs_init
.py", line 18, in
from pandas._libs.interval import Interval
File “interval.pyx”, line 1, in init pandas._libs.interval
File “hashtable.pyx”, line 1, in init pandas._libs.hashtable
File “missing.pyx”, line 42, in init pandas._libs.missing
AttributeError: partially initialized module ‘pandas’ has no attribute ‘_pandas_datetime_CAPI’ (most likely due to a circular import)
Does anyone know how to solve this problem? Thank you all.
You are probably better off installing requirements via the # r: modulename, modulename, modulename approach. Like this:
  **Thank you for helping me answer the question. When I added the new code at the beginning as you suggested, it threw a new exception error.**
Perhaps rename your script from pandas test.py to say my_test.py. Also, if that still fails, perhaps try resetting your Python 3 runtime (through the Tools > Advanced menu of the script editor).
Thanks a lot ,i will try.
I’m wondering if anybody has some other advice for this. I’m getting the same error and the above suggestions don’t seem to be working.
me 2 bro, Ive tried many times with pip and conda, always get the same error, btw im using R8 with MacOS Sonoma 14.0
Ive installed successfully openpyxl with whl. file, download from openpyxl · PyPI, just copy and paste into the folder like this: /Users/xxx/.rhinocode/py39-rh8/lib/python3.9/site-packages.
in case u need
I have a same problem, and Though I tried @nathanletwory 's tips but it didn’t work for me.
I hope this could be solved soon, because I was thrilled to use pandas in Rhino8.
I solved this problem. You should add C:\Users\User.rhinocode\py39-rh8\Scripts to Path Environment. If not, Rhino python find pandas somewhere else(maybe my local pandas) and It occur cyclic errors.
This didn’t solve for me.
Did you do something else besides adding Scripts to the path?
Does this work?
hello i’ve got the same problem… my script:
#! python3
#r: psycopg2,pandas,openpyxl
import scriptcontext as sc
import openpyxl
import System
import System.Collections.Generic
import Rhino
import psycopg2
# import locale
# locale.setlocale(locale.LC_ALL, 'en_US')
import pandas as pd
it return a error message:
Is this in rhino or grasshopper?
Using the newest rhino service release may help.
it’s in rhino… i think I use the last release…Version 8 SR5 (8.5.24072.13001, 2024-03-12)
I had to set local before pandas in this code. In yours it was commented out, is that for a reason?
#! python3
# r: pandas
import math
import System
import Rhino
import locale
locale.setlocale(locale.LC_ALL, 'en_US.UTF-8')
import json
import pandas as pd
#prompt the user for a file to import
filter = "JSON file (*.json)|*.json|All Files (*.*)|*.*||"
filename = rs.OpenFileName("Open JSON File", filter)
#Read JSON data into the datastore variable
if filename:
    with open(filename, 'r') as f:
        datastore = json.load(f)
df = pd.DataFrame(datastore)
csv_file = df.to_csv()
print(csv_file)
Does that solve the problem?
This other thread seems to say that the locale must be locale.LC_ALL, 'en_US.UTF-8'
same problem…
This is a library order problem. For instance Pandas needs a specific version of numpy during the Pip install phase.
#! python3
#r: pandas, openpyxl, psycopg2
import System
import Rhino
import locale
import openpyxl
import psycopg2
import pandas as pd
print(pd.__version__)
By removing the other libraries first and getting pandas to work properly was the first step. Then the other two libraries can be added to install after pandas
I have been seeing this lately where PIP installs multiple libraries and there are specific internal dependencies that can conflict with other libraries. I think both Pandas and Openyxl can be a specific about numpy and scipy libraries they need.
I hope this helps.
Is it possible to specify a virtual environment location where the installation of Pandas works? Because I use Pandas in many scripts that utilize virtual environments, and it works perfectly fine.
thanks!
