Rhino 8 hatch scale according to detail scale SECTION STYLE
I’m using the new Rhino 8 feature which is the section style. I would like to cut the same object and display the hatch pattern in different détails with different scales. The hatch pattern scale should kind of follow in an annotative way I’d say. When the détail is 1/50 the hatch pattern should have a different density as when the détail is 1/200 for example. I that feasable somehow ? Didn’t find any way or workaround.
Thank you
I agree, this would be really handy to have - being able to set the scale of the hatch per viewpoint!
I second that. Maybe just having a hatch scale setting in the Detail Viewport properties would do it.
This is a must have, did anyone figure out if this functionality exists?
