In the meantime, you can use these a GH Python component in your Grasshopper definitions to set the Model Linetype Scale from your Grasshopper definition.
Thank you @mary ! That’s perfect, I’ll test the Python and that should be plenty adequate in the mean time. Much appreciated!
EDIT:
I tested the R8 “LinetypeScaleV8.gh” and it worked perfectly. Thanks @dale
EDIT 2:
I modified the C# script to include the ability to toggle the Enable Model Space Annotation Scaling.
By default I turn this off. I’ve found in working with the new Grasshopper Annotation/Drafting nodes it gets very confusing (to me at least) switching between styles and having scales vary wildly amongst leaders, text, etc. I’m choosing to start everything with a baseline of 1 and then scale everything inside the local Grasshopper components to a scale that makes sense and that I can control easier from within GH
Code here in case anyone wants it:
public class Script_Instance : GH_ScriptInstance
private void RunScript(double S, object B)
//Assign Tooltips
Component.Name = "Set Document Model Scale";
Component.NickName = "Model Scale";
Component.Description = "Set the Rhino document Model Linetype Scale factor. \nThis factor scales all linetypes globally.\n Toggle Model Space Annotation Scaling";
Component.Params.Input[0].Name = "Linetype Scale";
Component.Params.Input[0].NickName = "S";
Component.Params.Input[0].Description = "Set Document Model Linetype Scale Factor \nDefault = 1";
Component.Params.Input[1].Name = "Enable";
Component.Params.Input[1].NickName = "B";
Component.Params.Input[1].Description = "Set True To Enable Model Space Annotation Scaling";
//Set Document Model Linetype Scale
var linetypeScale = RhinoDocument.Linetypes.LinetypeScale;
if (S > RhinoMath.SqrtEpsilon && S != linetypeScale)
RhinoDocument.Linetypes.LinetypeScale = S;
//Set Document Model Space Scaling
Rhino.RhinoDoc.ActiveDoc.ModelSpaceAnnotationScalingEnabled = B;
That is a document setting. A quick test of different factory-default templates shows that all of those have that setting set to 1. Perhaps you have a modified template that you use as the start-up template?
Thanks @wim for confirming! I’m glad to know it’s just a user error on my end. I don’t recall ever modifying a template but I certainly must have at one point.
You are possibly running into RH-88905 Linetype: Curve is Drawn where Shape Is
If you use a polyline, the base curve is currently drawn through the shapes. In a single line or a curve, that is not the case.
If you are running into something else, please provide a 3dm file.
