Will_Marx
(Will Marx )
February 1, 2026, 10:40pm
1
Hi All,
Rhino 8 Crashes every time I open the Properties Panel.
This has only begun happening since I downloaded for Enscape for Sketchup. Not sure if this is a coincidence. I’ve uninstalled Enscape and the problem keeps happening.
Can anyone offer any recommendations. I’ve updated Mac OS and Rhino to no avail.
Any help would be great.
Thank you.
Gijs
(Gijs de Zwart)
February 1, 2026, 10:41pm
2
If you can still run Rhino, run _SystemInfo and post back the results.
Will_Marx
(Will Marx )
February 1, 2026, 10:57pm
3
Thanks Gijs.
Rhino 8 SR27 2026-1-19 (Rhino 8, 8.27.26019.16022, Git hash:master @ a7029e543145704b986eede4bc40b6bd8a0645d0)
License type: Commercial, build 2026-01-19
License details: Stand-Alone
Apple macOS Version 26.2 (Build 25C56) (Physical RAM: 48GB)
Mac Model Identifier: Mac16,7
Language: en-AU (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M4 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
Thunderbolt Display (2560 x 1440 @ 60.00Hz)
GPU Vendor: Apple
USB devices
Apple Inc.: Display Audio
Apple Inc.: FaceTime HD Camera (Display)
Apple Inc.: Apple Thunderbolt Display
Apple Inc.: Apple Keyboard
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.27.26019.16022
Will_Marx
(Will Marx )
February 2, 2026, 12:28am
5
Apologies Gijs, I keep trying to add the sysinfo but it keeps getting flagged as spam and temporarily hidden.
Gijs
(Gijs de Zwart)
February 2, 2026, 9:47am
7
@Will_Marx I did not see anything suspicious in your system info. I’ve asked if a developer can look at your crash reports.
Will_Marx
(Will Marx )
February 2, 2026, 8:17pm
8
I’ve hit reset Rhino and this seems to have rectified the issue. Thank you Gijs.
Gijs
(Gijs de Zwart)
February 2, 2026, 8:20pm
9
good to hear @Will_Marx that that solved it, thanks for letting us know.
