I am experiencing a consistent fatal crash when trying to evaluate a pytorch model. I am able to install pytorch successfully and use a pretrained model for evaluation inside of grasshopper (amazing!), however after closing and reopening rhino, any attempt to evaluate the model instantly crashes rhino and grasshopper.
I can get the evaluation working again if I completely reset the python runtime and do a fresh pytorch install again in grasshopper, but I cannot close the file without repeating this process.
Interestingly, other torch operations seem to still work without crashing rhino. It seems to only be the model evaluation piece that causes the crash.
Rhino 8.3 RC does not crash and I think has a fix for this. I opened Rhino multiple times, opened the rhino file and Grasshopper definition and it is running perfectly fine. 8.3 RC should be out today so I’d appreciate if you can test it as well.
BTW do you mind if I keep this example as part of my unit tests to make sure pytorch is working?
