Hi all,
i haven’t found anything that might relate to the situation im currently in, but here is a short rundown of the situation.
So i created a surface (for a boat), and its a u=3, v=3 degree, deformable surface. up to this point, everything has been ok, but since i have manipulated this surface to the point that i can not redo it the same way, i am looking for a way that i can add chines to the surface.
Basically, i am wondering if there is a way, to change a certain portion of the surface to be u/v 3 degree and deformable, then the portion where my chines come should be u/v 3/1 degree and then the bottom hull should be u/v 3/3 degree.
Or if that is not a possibility, is there a way that allow me to have a deformable surface, but somehow it does not affect my chines?
