Hello
Why normal map looks good when the render start than it become bad?
No answer ?!
Isn’t a bug ?
I haven’t had time to check yet.
That first image looks wrong too…would it be possible to get the model?
I found the problem, and I have a fix ready for this. Essentially I’m writing the normal pass more often than necessary. You can follow here: RH-63236 Normal channel looks incorrect
Thank you
Excellent waiting for it
PR is cooking. Should be in the next 7.5 SRC.
RH-63236 is fixed in the latest Rhino 7 Service Release Candidate
