Whenever i try to print image the entire file crashes. Happens for some of the view modes like render/artistic. Only managed to do it successfully ONCE.
My laptop has a 16gb ram so I doubt that is an issue.
Please run the Rhino SystemInfo command, copy the results, and post them in a reply.
Hopefully something obvious will show up.
This is mostly likely a problem with an old GPU driver or a plug-in.
System RAM is not at all likely.
