I’m currently following a tutorial from rhino 5 but I’m using 6. I try to use curve network but I dont see the preview option or the result don’t show the surface if I press OK.
I do have the lastest version of rhino 6.
Can someone help me understanding why?
Hello - please post a file with the curves.
if you don’t use the middle curve. it works fine:
Hello - to make a valid network in this case you need to make sure all the long-ways curves actually meet at the ends - they are a little off.
Ohh I thought checking the connections. Thanks guys
