Rhino .3dm import blender plugin improvements
@nathanletwory
Thanks, much obliged for your work on this.
RM
I released yesterday v0.0.13, which fixes a script failure in Blender 4.1 and later (because Blender API got changed from 4.0 and earlier).
Hi @nathanletwory
Glad to see you up so early,
Is this the right one for me I’m on windows 11?
“import_3dm-v0.0.13-py3_11-windows.zip”
RM
Summer vacation is over now, so I wake again early and start working early (around 06:00 in the morning).
The release page has information on what version to download for which Blender version. Windows version doesn’t matter.
Ok that’s good to know. I’m stuck on 4.1 for now because of EVEE bloom change in 4.2
RM
Yup, Blender changes a lot, and not always in great ways - long ago I tried fighting against breaking APIs a lot (between subsequent release versions, essentially 3-4 times a year), but I gave up on that. I don’t think there will be ever any stable API ever. You’ll be just told to stick to an older version.
Yea they move too fast for my aging brain to keep up with. I do think they have really made tremendous progress and have improved it to the point of true usability. It’s really an incredible program I used to hate it until they changed the GUI. I’m throwing millions of polys and doing mixed renders with different scenes using cycles for backgrounds and evee for foregrounds and compiling them with crowds and custom rigged characters it’s insane how good it works. The animation rivals if not being better than 3dmax.
Really appreciate your plugins and help.
RM
I’ve released v0.0.14 of import_3dm, visit https://www.rhino3d.com/download/rhino/8/import_3dm/ for the add-on.
Changes:
  • add vertex color support
  • support text annotations
  • properly add a rhino default material
  • fix double empty material slot
  • add a default material for annotations (black plaster) so that they are better visible
hi @nathanletwory, thansk fo rtshi update. after I tried to install the unblocked .zip, I got this error. Any ideas what could it be?
Thanks,
G
Is there a version for Rhino 7?
RM
You did download the zip for py310?
Not sure I understand the question. The rhino3dm version used is based on OpenNURBS 8.9. It will load any 3dm file from Rhino 8 and earlier.
FYI, I can can get similar but different errors in Blender 4.3.2
As per installation instructions on the github repository: install, restart Blender, active addon.
Super.
Sorry, I managed to get Ivygen(?) activated without a restart. Though I did restart it the first time, and still got the yellow triangle.
Restarted again, and it seems fine. User error.
Thanks.
Hi Nathan.
Just installed the latest v0.0.16 of the “import_3dm” add-on for Blender but can’t get-it to work. I do get a "No module named ‘rhino3dm’ " when I do try to activate the “Import Rhinoceros 3D” add-on. I am using Blender 4.5 LTS on a Windows 11 machine.
Make sure you download the file with extension in the name and install that.
On the release page:
Hi @nathanletwory
I just tried your plugin in 4.5 and I keep getting an error. Module 3dm not found. Now I can’t uninstall it since it only reports the error. I unblocked the file before trying to install. Where is your plugin located in blender so I can delete it manually.
Thanks,
RM
I think you can just install the extension instead. But Blender add-ons/extensions are placed under %APPDATA%/Blender Foundation/Blender/4.5/scripts/addons. Use that string in file explorer, it will lead you to the correct location on your machine. Then install the extension instead.
Myself I do managed to install the importer using the Extension version instead of the add-on one into Blender 4.5.
FYI: You can drag and drop extension zip file on blender to install them.
It will prompt you to choose a repository. In most cases “User Default” is what you want.
