hi
i’d like make Rheotomic surface like this video
i got Rheotomic tool but it’s a plane surfaceRheotomic_Surfaces 0501.gh (34.3 KB)
so I need a stacked, repetitive surface.
i think i need to extract domain and u,v line on existing surfaces
or using contour
I appreciate any way that is similar to that video
You need to change the option to streamlines like this Rheotomic_Surfaces_helicoids.gh (31.1 KB)
Thanks daniel
i’ll use this for architecture plan ,but there is an inappropriate part.
each floor is separated
![3](https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/6/1/61093f62803de22b897b935cba4c75051c17121c.jpg)
![4](https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/3/8/38bc75d14d49301580ce001b740cb9125ad79ddc.jpg)
i think this mirrored stuff can be better
in this case for a smooth connection, part of the top and bottom of the green line should be cut and connected using weaverbird subdivision
How to classify and select green lines?
