RGB to Adobe Hex Colour Plug In
Hi All,
I was just wondering if there was a plug in where you pass in RGB’s and it returns a Hex Colour code you can then copy into Adobe programs (ie. photoshop etc). Just to save copying in 3 different values.
Example of the interface on Adobe colour which allows you to turn RGB to Hex.
https://color.adobe.com/create/color-wheel
A single line of c# can do that.
using System.Drawing;
  private void RunScript(System.Drawing.Color Color, ref object Hex)
    Hex = System.Drawing.ColorTranslator.ToHtml(Color);
2021-09-08 12_09_14-Window
c#_color-to-hex.gh (6.9 KB)
Amazing @maje90
Is there a way of doing the opposite, where I pass in a Hex value and it spits out the RGB?
Thankyou so much! Sam
I’m using the attached definition to convert hex to rgb.
hex_rgb.gh (10.0 KB)
If you also want the alpha value, I use the following:
Color to Hex using Regex
  private void RunScript(System.Drawing.Color color, ref object hex)
    hex = String.Format("#{0:X2}{1:X2}{2:X2}{3:X2}", color.R, color.G, color.B, color.A);
Hex to Color
(from stackoverflow)
  private void RunScript(string hex, ref object color)
    hex = hex.TrimStart('#');
    if (hex.Length == 6)
      color = Color.FromArgb(255, // hardcoded opaque
        int.Parse(hex.Substring(0, 2), System.Globalization.NumberStyles.HexNumber),
        int.Parse(hex.Substring(2, 2), System.Globalization.NumberStyles.HexNumber),
        int.Parse(hex.Substring(4, 2), System.Globalization.NumberStyles.HexNumber));
    else
        int.Parse(hex.Substring(6, 2), System.Globalization.NumberStyles.HexNumber),
I’ve also have both of these in the Heron add-in.
-Brian
Is the opposite possible? I have hex colors and I need to unput them as a material color.
Why not using this ?
I’m already doing this. However, I am given a set of Hex colors, I’m bringing them into Photoshop, looking up the Hex color, and then copying the CMYK values into grasshopper. If I am able to input hex color codes directly, it would save me tens of minutes a day over the course of this project.
This should do it no?
I don’t really understand your workflow. Could it be possible you describe it more clearly ?
If Hex color you can use the above script to transform to RGB color then use a component to transform it to CMYK.
I have done one in Nautilus for that
Martin! I skimmed over this - thank you! Exactly what I need
