Hey all,
I read some topics on how to use [item index] or [member index] but I still don’ t manage to solve this issue.
I have a set of curves as in figure
the first list is a set containing some nulls. Doing an offset of the curves it just takes the real curves and in the end i don’ have the nulls anymore, but just the offsetted curves.
What I need is to have the nulls in the same index positions after the offsetting, because i need the curves to match in number and positions before and after the offset.
I was thinking to use item index+ insert item but as I read in the other topics if I type “null” as element of search is not working. I got that this is not working cause the two nulls are not the same…
How can i Solve this issue?
mind that the number and the position of the nulls are variable so what I need is to keep is the pattern curves-nulls.
I upload a simple file with the same issue just simplified cause the original file is huge.
(I would find a way to keep the pattern rather than than re-applying all the 0 “manually”, as before the offset)
Any advices?
Thanks
Example.gh (5.7 KB)
